Okay, long story short, my old computer went bad. So, I have to order and put together a inexpensive one. I want to keep my videocard which is a 6800 GT, but is AGP. So, I ordered a motherboard, hard drive, new processor, and memory.
Now here's the problem, the 320gb. hard drive (http://www.newegg.com/product/product.asp?item=N82E16822136098) I ordered for $99 from newegg is SATA 3.0 Gb/s, and the motherboard (http://www.newegg.com/product/product.asp?item=N82E16813130064) says under storage devices, SATA 1.5 Gb/s "2." So, I called my buddy and he said the hard drive I ordered will not work with the motherboard. So I just thought that since Serial ATA150 was older technology, it would be cheaper, but no. I search newegg for a hard drive that will work with that motherboard, and I get 1gb/ $1?! So, a 160gb. one costs $125. Wtf?
So basically the way I see I it is i'm screwed b/c there are no motherboards that support AGP video cards, that are CPU socket type AM2, and work with SATA 3 hard drives. I need some help as far as what I should do, b/c either way i'm going to have to send something back. I'd really appreciate some help.
Thank you all.
Thank you all.
