I need some advice about an upgrade
Does this actually matter? It's not Kingston, I know that much. I'll take a look when I get home from work.
If you have to send it back, and get something compatible, then Yes it does.
if you have cas9 at 1.5v, and you buy cas7 at 1.65v, do you think everything is going to go 100%right for the memory upgrade? Personally, iI like to match voltages and match cas latency, especially when it can be done usually for less than $10 difference.
Okay, thanks for the post. I'll check on this as soon as possible.
Another alternative is to sell the current 3GB kit and pickup a faster 3x2GB kit of DDR3-1333/1600 instead. ;)
Unfortunately, the guy from Ebay (thanks for the link, gwarren), won't ship to Canada. So maybe I ought to do what enginurd suggested, and buy a 3x2GB kit of faster ram.
Okay, I'm in the weeds now.
Could somebody recommend something from NewEgg Canada?
ASUS P6T Deluxe, Core i7 920 - I don't over-clock.
$128 - G.SKILL 6GB (3x2GB) DDR3-1333 F3-10666CL9T-6GBNQ
Hopefully you can sell your 3x1GB set for half that. ;)
