Guys, I feel is time I upgrade my tired E6300 but I really have no idea what to get, I also know that I don't want to break the bank while doing it.
My Specs:
Windows XP Pro W/SP3 32Bit... I still don't feel like going to Vista but perhaps in the future so I want to keep that in mind for my CPU purchase.
Acer 22" W/S LCD Monitor
EVGA 680i SLI Mobo
E6300 @ 2.8Ghz w/Artic Cooler 7 Pro
ECS 8800GT W/passive Accelero S1 @ 700/1744/1000
OCZ 2GB 1066mhz Ram
Samsung 700GB HDD
This is basically my Gaming Rig, I only do FPS games and not for MP play at all. Std e-mail checking and internet Browsing but that's about it.
Right now, when the rig is loaded with a game (1680x1050 res), the 2 cores can easily get to + 60c and then, the mouse starts to stutter and move erratically, hence, the need to upgrade to something that can handle the games and maintain a lower temp.
From what I have been able to read, the Q6600 is one of the choices I can go with but then, there is the E8400.
I know you guys are fanatics of O/C'ng and all that, I am not all that crazy about it and I only did it to the E6300 in order to hold the upgrade a little longer.
Knowing this, what would you recommend I look for? 200 bucks is the max I am looking to spend here so let's get the best bang for the buck (hopefully
Thanks
My Specs:
EVGA 680i SLI Mobo
OCZ 2GB 1066mhz Ram
Samsung 700GB HDD
Thanks
