I need help - Not sure what this problem is!
Brucie
Hi Guys,
I just brought the following
Asus P5QL-EM
Hiper 580W PSU
Q6600
Kingston DDR2
When i press the power button to boot my system it takes a sec or 2 to kick in and when i press the reset button it takes 3 seconds to restart and 3 seconds to kick back in to life. I have tried connecting the monitor into the DVI and VGA port on the motherboard and i have nothing showing just a blank screen and amber light.
I have brought down my system to its base to help with this issue so i only have the motherboard, PSU and CPU in my system installed. I have no other cables connected apart from the case power button cable.
Can someone please help!
Thanks,
Ok, so you have the CPU 8-pin and the 24-pin pwr connected though correct? If so, throw in one stick of RAM, see if you get any post beeps.
I have the 4 pin and the 24 pin pwr connected, just thrown in a stick of ram and still not getting anywhere. I can't hear any beeps, i don't think my case has a speaker.
Hit up the Basic Troubleshooting Guide on what to do when your system does not POST.
Oh which Hiper 580W PSU did you buy?
