I need an overclockers value 775 board..help?
play2lose
I'm finally gonna upgrade from my old AMD 64 3500+ =p
Thing is I'm completely lost when it comes to these new boards!
All i know is that I need a LGA 775 socket board and new DDR2 ram lol
I'm also pretty sure I want to go with the E6550 for my CPU...they seem like the best value since I'm just gonna OC it lol.
I found some Mushkin 2x1gb DDR2 800 CAS4 ram kit on newegg for like 60$ looked pretty good. For motherboard I want something under 100$ but more around the 70 mark. I want it compatible with DDR2 800 and also has decent overclocking options. im not looking for some asus extreme striker type board...as long as I have a few options to OC im fine. Im thinking some of the Gigabytes under 100 look like a pretty good value OC board. any suggestions or help? thanks =]
Abit IP35-E is the best budget OCing board I've seen. I have a 6550 running at 3.0Ghz with no problems at all.
I got the giga ds3l and some gskill at 1000 running on a e6400 at 3.5ghz at 1.45 volts.
all real cheap to buy. lowered the multi to 7x 500,all are at even numbers now looks nice.............
Another vote for the Abit IP35-E. Running an old e6600 at 3.6ghz with no issues as well. Extremely simple to overclock with and it comes with great overclocking features.
2 votes DS3L
2 votes ip35-e
-_-
lol. im leaning towards the DS3L just because the abit isnt available on newegg any longer and I've worked with gigabytes in the past and loved them.
I'd suggest checking out the DFI Blood Iron (P35) and the MSI P35 Neo-2 FR. They can both hit 550FSB (basically guaranteed, 600 is possible on some) with a dual core and a decent fan on the NB.
MSI on Newegg
Blood Iron on Newegg
Blood Iron review
MSI review
edit: Just found your price limit. The MSI is $100 before shipping after a $20 MIR and the DFI is $110 before shipping, no rebate. If you're looking for a high FSB board, I'd say it's worth the extra $ for either of these two.
The only thing is that the IP35-E is about $30 cheaper than the MSI board and $50 than the DFI board if you get it during a rebate period. I never had a problem with Abit paying rebates so far. The only catch is the quick turn around needed to submit the rebate.
Another IP35-E vote just a awesome board. It oc's very easy, good bios layout, over all a great board, oh yea and cheap. I have my E6600 running at 3.1 with no adjustments just up the fsb and go! I've had it up to 3.6 @ 1.49v or so stable enough to run 3dmark06
If the OP is definitely going with a 6550, then the IP35-E is the right board. If he wants to go with a cheap Penryn and heavily OC it, he should probably get a higher FSB board. I'm just throwing this out there so he has a few options.
I do agree that the IP35-E is a great board for Conroes and moderately OC-ed Penryns though.
Had cold boot issues with the Gigabyte P35-DS3L so I switched to the Abit IP35-E and so far so good. Another thing to consider is the fact that the DS3L lacks passive or active cooling on the PWM, so unless you have excellent case cooling you might run into problems later on with large overclocks with that board.
No problems getting my DS3L up to 450MHz FSB on average case cooling. No boot issues either. Excellent board all around.
I've had dual boot issues with both IP35-E's and DS3L's... but more common amongst the IP35 boards. My IP35 does it, but my DS3R (nor any DS3R's I've worked with) does not.
My vote is for the DS3L if you're OC'ing, simply because it stores your BIOS profiles. I know, my DFI spoiled me, but that feature is just so fkn convenient!!!
You'll need additional cooling on either board if you want to go above 425Mhz FSB SDR -- as in add a fan to the NB or replace the NB HS w/ an HR-05(-SLI) or something.
I'm also researching "budget" clocking wonders of the P35 flavor and another that I came across is the Biostar TP35D2-A7. So far this one and the Blood Iron are the only ones I saw hit around 600 (both using extreme cooling however, air will probably bring the max down). The Biostar uses a craptastical PCI gigabit controller but I don't think that'll affect 100Mbps operation much. The BI has the ICH9R chipset for RAID and NCQ funtionality and an extra two SATA slots. The only thing I don't like about the BI is the sticker on the NB cooler that voids the warranty if you even want to redo their likely crappy TIM application, let alone replacing a woefully inadequate aluminum passive heatsink. It is also more expensive than the IP35-E/DS3L/TP35D2 crowd.
Anyone know about the missing 533 divider in the TP35D2-A7? Did the mod Bios fix that?
Yeah I'm a bit confused as I'm used to HT and HTT in relation to the mem clocks, but the issue seems to be forcing 3:5 ratio with Allendale (800 FSB) chips because the NB won't run memory 1:1 at 200 (from what Polygon said). It appears it might be fixed by the BSEL mod or later BIOS versions, but failures to POST remain.
What concerned me was this post at RHF:
I got a problem with mem dividers though... In all BIOS's that I tried, I only get [Auto] [667] [800] options and a couple higher values. Flashing bios 823 added [400] but I can't get any other divider like [533] which would be suited to my system.... I also tried RH bios but nothing...
I can pull my CPU up to about 3.2 GHz, 360 FSB x 9. At that speed with divider [400] my RAM runs at 720 Mhz, while with divider [667] runs at 1200 (which requires high voltages and super-loose timings). If I could run them at about 900 Mhz with a [533] divider it would be ideal.
This also seems related to the failure to POST randomly issue that has to do with the board changing the strap. Sometimes it boots at performance level 8, others 12, one guy said his likes to change to level 4, causing definite failures to POST.
Speaking of P35, have you noticed the Abit IP35-E dropped from Newegg and MWave? Don't tell me they plan on EOL the E version and leaving a gap between the V version and vanilla board.
edit- I guess the 3:5 issue (fixed in later BIOS) is separate from what I'm talking about, according to Goldfries, the above quote describes it. With 800 FSB chips, there is no option for running asyncronously a certain ratio when overclocking so it's difficult to achieve ~3GHz clocks and have the memory in the 900-1000 semi-tight territory. Does the IP35 series have this issue with 800 FSB chips? Also, is the 4-phase regulation a better idea for future Yorkfield clocking?
of course it could just be that it's sold so well that abit USA got caught out on their stocking levels & are waiting on a shipment.
It's certainly still widely available in Europe.
I hope so, it looked like the board to beat in this section of boards. I don't need AHCI, but the ethernet and VCore regulation are interesting. Its color scheme and general design looks nice and clean too. I think it put Abit back on the map singlehandedly. It would be dumb volume-sales wise to leave a gap between $80 barebones and $130 heatpipe/AHCI perks.
To get an Allendale (800Mhz FSB QDR) to 3Ghz while the RAM is at DDR2-900, I would assume your CPU multiplier is 7. That config would perform no better than a 9 x 333 config, since the resulting clock speed is the same, despite the higher FSB and RAM speeds. The current Intel platform performs best with the CPU and RAM at a 1:1 ratio -- so overclocking just the RAM doesn't help performance much, if any at all.
4-phase as opposed to 6 or 8 phase?
Thanks, starting to get it. So 1:1 at 333 would produce '667' memory speed? Does anyone ever run high FSB with mem at lower speed for tighter timings, or is 1:1 with loose timings optimal?
No, compared to 3 phase of most (or all?) boards in the ICH9 price range, the IP35-E is the only one with more than 3 phase. Just curious if this will come in handy for quad clocking.
Not single-handedly - the AB9 QuadGT started it & the IP35 Pro continued it along with the IP35-E.
Excellent, hope they keep their momentum.
You won't notice the difference between CL4 and CL5 unless you're running benchmarks. And even then, the difference is negligible. So, don't pay a huge price premium for the same speed ram with lower latency -- its just not worth it.
On Intel platforms (chipset/chip), there are no memory dividers -- just multipliers. So, you basically cannot run the RAM lower than the FSB... the RAM speed will always be at least twice the FSB SDR. I've heard the nForce chipset has some dividers, but I'm not certain of that.
/*------------- <cut n paste> -------------*/
Formulas for Intel platform @ 1:1 settings: (base FSB speed is SDR, or single data rate)
c × [Base FSB speed] = CPU Clock speed (c = CPU Multiplier)
2 × [Base FSB speed] = RAM speed (DDR: double data rate)
4 × [Base FSB speed] = Effective FSB speed (QDR: quad data rate)
On Intel platforms, running the RAM higher than a 1:1 ratio with the CPU is, for the most part, useless, so don't bother trying to do so. If the BIOS does it for you, just let it. All you need is a 1:1 config, though. Here's some possible clock speeds (as always with OC'ing, your results will vary):
E4500: 11 × 200 = 2.2Ghz, DDR2-400 << STOCK speeds (RAM will auto OC on P35)
E4500: 11 × 266 = 2.9Ghz, DDR2-533 << Easy OC (RAM will auto OC on P35)
E4500: 11 × 300 = 3.3Ghz, DDR2-667 << Great OC
/*------------- </cut n paste> -------------*/
I believe, in general, the more the merrier. However, the 3-phase boards should be able to handle quad clocking quite well also. The Gigabyte DS3L has 4-phase as well, IIRC.
Man, if the forum had the facility I'd rep you enginurd, I appreciate it. Still tough to decide on a board, especially since the DS3L shares the better regulation than the group with the IP35-E and even has full solid caps (four distinct groups of fets, you're right). So many glowing reviews of each brand's offerings, yet a few squeaky wheels here and there.
afaik the IP35-E is generally adjudged to be the better overclocker between it & the DS3L.
Solid caps only come into th eequation if you intend to keep the board for a very long time as the only difference between then & equivalently specified electrolytics is durability.
Nobody's perfect. ;)
Totally. I would hate to see a human with double boot or failure to POST issues though :D
Thanks BUFF, although I do tend to hang onto hardware as long as possible, I probably won't be running it long enough to see the solid caps turn in a difference. Definitely helps.
