You see I saw something the other day that I have been wondering about.
I was hooking up my new SATA drives into my computer and I pulled out what I thought was a 4-pin molex to Dual SATA power connectors. Well when I went to go plug it in I found that the 4 pin connector was the wrong connector, it's the male instead of the female. It's the same connector that is on the PSU, I couldn't plug it in... WTF?
What is this cable for?
This is what I thought it was.
This is driving me crazy, I just went through Newegg and cannot even find this cable anywhere.
I also have a SATA > eSATA cable that I attempted to use to hook these drives up...till I realized that one end was eSATA and I have no eSATA spots on the computer.
Here are some pictures..Click for higher resolution.
Also I now have 3x300GB + 1x320GB
Should I do RAID5 with the 3x300GB and keep the 320GB for backup?
or
Should I do RAID5 with 4x300GB?
What If I had the 3x300GB and later on, once I have data on the RAID5, can I just come in and add the 320GB or another 300GB later?
While I'm at it.... What's a good program or two to test hard drive speeds?
or
