I need a new case
That and or the H500P Mesh. Airflow is not an issue on the Phanteks.
This bad boy right here. Cable management is a snap, comes with good stock fans and a PSU shroud. Easiest case I ever built in and looks good.
https://www.newegg.com/black-phanteks-enthoo-pro-atx-full-tower/p/N82E16811854069?Description=Phanteks enthoo pro&cm_re=Phanteks_enthoo_pro-_-11-854-069-_-Product
second this but recommend the solid panel or tempered glass versions. absolutely do not get the windowed version since it uses a thin plexiglass and has a tendency to expand and contract with the internal temp of the case and will randomly make popping sounds.
as far as cooling goes, it's pretty good especially for the 100 dollar price tag(non tempered model).. the top vent can support a 360mm rad or 3 140mm fans.. i won't use my temps as comparison though since mine is a pretty specific case given my room stays a constant 64F year around in the basement so my temps are stupid low.
the only thing i personally wish was different is that they had put the front panel IO around the power button pointing up instead of sticking out the front since i already broke 2 dongles for my wireless headsets hitting them with my knee in the dark.
I love my Phanteks Enthoo Pro M with tempered glass:
Based on your wants and needs, one option might be to sacrifice the D15 cooler and get a Corsair 200R with a BeQuiet Dark Rock TF and feed it from the side panel with x2 140mm fans (or 120mm). The 140s on the side panel will force the air directly into the TF and there will not be much clearance between them once everything is together in the case.
