Ok i recently upgraded my Graphics card to a HIS 4850 and was told my PSU isnt good for this Card.
Specs:
Dualcore 4450e
ECS Mobo
3gb ram
1 DVD DL burner
640GB sata WD HDD
Antec earthwatts EA430 430W: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371006
HIS 4850: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161244
My question is i posted up on the ati forums about my card was asking a ? and someone asked me my setup so i told them. then some people went nuts saying that my PSU is not good enough to run my vid card
one of the comments: you'd do the card a LOT of justice by running it from a certified and capable PSU aswell, that unit ain't rated by ATI for a single HD4850 .. your PSU outputs 17A MAX @ 12v or ~14.5A and your card draws around 15.5A under load .. you're gonna run it into the ground or something might go POP if you run it close to the limits of that unit
am i worrying about nothing or is he correct. I was told by some hardocper's to get this card and PSU so i did.
Specs:
Dualcore 4450e
ECS Mobo
3gb ram
1 DVD DL burner
640GB sata WD HDD
