i hate vista?
Status
Not open for further replies.
its just not ready yet it still have some problems.
i would turn it on and it would say cant load desktop.and i would have to reinstall vista
it would say error and wouldnt load desktop
That just doesn't happen unless it wasn't installed right, you have failing hardware, or someone is deleteing stuff they shouldn't be. How are you installing it and where did you get Vista?
/me waits for the hammer to fall... the one where the OP admits to some downloaded copy that could have been h4x0r3d to pieces with vLite or customized with all sorts of useless stuff... or the admission it's being installed on a 12 year old Pentium 133 box... or something in a similar vein... :)
yet another fine example of a totally useless thread....sounds like a driver problem or hw failure.........
As you've realised by now, Vista is a terrible OS, because it kicks puppies and mugs little old ladies and will use the last of the milk and never go out to get more. The people from the Internet assure me that Windows 7 will clean behind its ears and give you a relaxing massage if you're having a bad day, though. So ignore anyone who claims Vista is fine and Windows 7 is an evolution of the same platform, they don't know what they're talking about.
...but only after the installation od Service Packs 1 & 2 :p
I'm closing this only to stop the numerous Reports on it.
Status
