Though luck my friend.
What do you plan to hook up the disks to?![]()
You do realize if you contact newegg they will usually give you a refund for the reduced price.
Once 2.5TB+ drives come out it's going to be funny. Anyone with Windows XP will not be able to use them do to the limitations of MBR.
also confusedYou hate them because prices on computer components are decreasing over time?
?_?
Windows users will be able to use them, They will just have to make more than one partition. Also according to this http://en.wikipedia.org/wiki/GUID_Partition_Table, vista and 7 will have the exact same limitation. Correct me if i am wrong though I do not follow such things very closely since I do not use windows.
