Hi guys! I recently got some A. C. Ryan mods to decorate my PC with...they were mainly light mods..Anyways, here are a few pictures concerning the questions below them..have a look
Now the questions:
1) I need tips on how to how the hide the inverters from the view... (See the second picture above)
2) Should the two fans (on the window) be blowing the air into the casing, or out of the casing ? Right now, both are set to be blowing into the casing... I am thinking that maybe the bottom fan should pump air into the casing, while the top one should be pumping it out. This way, the air would be moving from the lower front-middle part of the casing, to the top middle-back part of the casing. Also, air would be passing over the CPU and GPU at the same time...
3) Another problem I am facing is that the screws that came with the fans, are not 'screwing in' !!! This is because the hole does not have the diagonal 'lines' on it, which allow the screw to 'screw in'...I tried hammering the thing in, but that didnt help. The only solution I can think of is maybe trying to drill it into the hole using a power drill machine, very slowly...What are your views on this ? Am I missing some key point ? (See the third picture above)
4) I also have an LED canon light (not shown in any of the pictures) which I need to place somewhere, inside or outside the casing...Where do you suggest will it look best ?
Thanx in advance guys...
Now the questions:
