i got new memory and now i have problem!
dare8787
hi guys
i have a big problem!
i received from newegg today CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 .
My system is 32-bit. im using windows vista 32-bit and XP - dual boot.
when i read istructions for memory it says - 64 bit only,using with 32-bit systems is not advised!
well i admit im total newbie when it comes to PCs, but now its late to change...
Now my question is -
1. can i use this memory with my system and will it damage comp?
2. what makes system to be 64-bit? do i need just to buy windows vista 64-bit or i need also some hardware that support it (besides memory) ?
thank you in advance!
Its probably saying that just because 32-bit systems will not utilize all of it. A 32-bit will only use 4gb total and if you have a 512mb video card you will only use 3.5gb of the ram. With 64-bit systems this is not a problem. I would go ahead and use it dont see how it can hurt anything.
1) You can use it and it will not damage your PC. However, you will not be able to use all 4GB of RAM due to 32bit limitations. At most you'll see and use about 3 to 3.5GB of RAM. Which leads to the next question...
2) All you need is a copy of any 64bit OS in order to use all 4GB of RAM. That's all. No need for special hardware or anything. If you're fine not being able to use all 4GB of RAM, then don't bother with a 64bit OS.
thanx for quick anwers guys!!
Danny BUi - are u saying it will damage my system or not ?
