SodaCose said:What have you tried so far?
What happens when you attempt to OC? Does it post? Does it boot to Windows? What are the temps?
CCUABIDExORxDIE said:drop the ldt down to 4x, some boards hate going above 1000mhz hyper transport, then see if you can oc. im betting that ram can do ddr430 atleast.
p0stal said:I have the MSI K8N Neo and a 3200+ Newcastle, here are my results so far.
http://home.comcast.net/~xvxdebrutsidxvx/cpu.PNG[img][/QUOTE]
I have the same mobo and those might be the best results you're going to get.
My own research has shown numerous people unable to oc the msi k8n nf4 past the 11% barrier, which is what i'm experiencing. I've tried almost every possible combination of settings, but it will not run past that point.
Which is why I've stuck with using the core center app to oc my rig. I had instability problems with my previous p4 rig and am experiencing 100% stability and faster performance with my new AMD rig.
