rpeters83
- Jan 11, 2009
I currently run a plex media server on a Windows 2012 Hyper-V server instance with 1GB allocated on a E6550 C2D machine. I have a spare netbook that also has 1GB RAM. I'm debating on whether to remove the hyper-v instance (and therefore freeing 1GB of memory) and putting it onto the netbook.
While this may be a question for the home theater section, it's more about the performance between the two. Would the performance of this hyper-v instance be comparable to a netbook with an Atom 1.6ghz?
So, basically...
Hyper-V instance on C2D E6550 at 2.3ghz 1GB ram
or
Raw hardware netbook with Atom 1.6ghz 1GB ram
Thanks.
So, basically...
or
Thanks.
