I know, this should be obvious, but i'm just starting to dabble in virtualization and ran into a roadblock and need some advice.
I'm looking at trying to consolidate some boxes into one and virtualize most of it.
Windows home server
Random services OS - torrent, ftp, apache, mediaservers
HTPC
Ideally it would be awesome to be able to put the HTPC on the same hardware as the other two, but I've not been able to verify one way or the other whether or not you can pass through the graphics card to a guest OS. Need the HTPC to be able to directly access the video card for 1080p and audio output over hdmi.
Is the above possible? or is the only solution to run hyper-V in server 2008 R2 and have the HTPC native to that OS so it has direct access and then virtualize the WHS and Services OS?
Thanks for the help, getting excited about taking nerdery to the next level
Windows home server
HTPC
