HardOCP News
[H] News
- Dec 31, 1969
Check it out, half the picture below is computer generated, half is real. The article seems like a commercial for KeyShot but the tech involved is still pretty cool.
think of the poor buggy whip makers
Ehh, i still can notice which half is real and which isn't, it is simple, look for the imperfections, or better said, the lack of them... like the lack of nose hair... gross but that should tell you fast which half is fake if you can't tell
Still, yeah, we may eventually get there, but i don't think that the real deal will be entirely phased,,,
There are a few nose hairs on the CGI side. There is not sufficient skin translucency to realistically illuminate the nostril, and backlight the nose hairs and not enough of them to be very visible from front lighting. There's also aliasing of the eyelashes. Those are probably technical limitations of the renderer. Then there's the laziness of the creator. Big blurry areas that don't quite match between the bump map for the pores and the specular map for the pores in the skin. All the beard hairs are black or gray, not the variety of shades and hues of natural hair. Very few hairs actual tangle with each other, just mostly lay against one another. Then there's the big screaming obvious thing which is the CGI skin looks pearlescent, that could be the renderer or the artist.
As for "To take a photo takes a few minutes". That just isn't true at a professional level. Setting up a professional product photo shoot takes a lot of effort and time in order to prep the scene and get the lighting perfect. In some cases, like food photography, the amount of effort that goes into making the food look perfect boarders on the absurd (ex. sesame seeds glued onto a burger bun to produce the ideal distribution pattern; cardboard under the burger patty to make the sandwich look firmer; etc.). With an all CGI setup, you could have a stock collection of scenes/actors and just swap up combinations and lighting settings once you have enough options created. As for the product itself, you can already import the actual 3D parametric CAD files created by the original design engineer. They usually include the actual material properties for each component making it a breeze to just render with total realism.
Why must they use this technology to kill people though? Why can't they just let the photographers be?!?!!![]()
If find it hilarious that car sites like http://jalopnik.com Look at pictures of new cars coming out and everybody in the comments and on the website talks about it like it is the real car but it is just a render in 3d studio max based off the autocad data with a .HDRI file applied for the lighting from the sun of a real location.
