HX620 powering a 4870X2
operaman
So my rig is as follows:
Antec P180 w/3 Antec 120mm, and 2 Panflo 120mm fans
Asus P5KC
Q6600 GO 3.03 GHZ stock volts
2 Samsung 500GB
2 RaptorX 150's
2 Samsung DVDRW
1 Plextor 755 DVDRW
8 GB OCZ DDR2 800 RAM
So the question is assuming I get the 8 pin connector from Corsair, will the 620 fall with in an acceptable range to run the 4870X2?
I am thinking I will be drawing in the 500-550ish range, but want to be sure by checking with the experts...
With what you have listed there you will probably be pulling around 250-300watts max (this is just what you listed, without the 4870X2 of course).
I think you should be able to power the 4870X2 in that mix as well with the HX620 pretty easily. The HX620 is a monster, and delivers what it says (unlike many that under deliver for the wattage).
Honestly most people way over estimate the power usage and wattage they need. New/fast parts does not always mean power hog, in fact C2D chips are many times more power efficient than the old P4s!
To give you an idea:
3.4ghz P4 (Power HOG)
2gb of RAM (RAM does not use much power)
2x400gb SATA
2x160gb SATA
80gb IDE
PCI SATA Controller
DVD-RW Drive
4x80mm Fans
1x 120mm Fan
With all drives spinning and being access it pulls around 225-240watts.
the 620hx would prob do fine, but in preparation for my 4870x2 I just ordered 1000hx
My system is
q9450 at 3.7
8gb ram
2x wd6400aaks raid0
dell perc 6i with 4x wd6400aaks in raid0
dvd drive
6x 120mm fans
water pump
8800gtx (to be replaced with hd4870x2)
currently all powered by 620hx with no issues.
your 620 doesnt have the 8pin connectors? 6+2. mine does. they must have changed it. mine is a year old.
im also going to be upgrading to the 4870X2 from a 8800GT with the system in my sig. going to put the 620 to good use.
The 620 will drive two 8800GTX SLI. It'll handle a 4870x2. I'll be upgrading to a 4870x2, as well. Corsair sent me a 6+2 cable so I'm ready to rock!
Q6600 OC'd to probably 3.6Ghz w/ 4GB ram
4870x2 OC'd under water
4 Scythe S-Flex fans
2x Raptor 150GB
2x AAKS (320GB/500GB) HD
2x Laing MCP355 pumps
I'm thinking that's too much for the 620HX.. so opting for something better.. 750w? 850w?
$260 for a PC&P 850w is rather high though.. i'm liking the Corsair TX750 a lot more.
2x Raptor 150GB
Why is it too much for the 620?
So you have:
Q6600 (~100w)
4 Scythe S-Flex fans (2.5w ea for the big ones x 4 = 10w)
4x HDDs (all newer models that are less power hungry, around 12watts ea max x 4 = 48w)
4870x2 (probably around ~200w but usually the max a video card can draw is around 300w)
2x Pumps (18w ea x 2 = 36w total)
So you have a total of 494watts with everything at absolute max power (which would probably not happen, and some of my things are high estimates like the video card), a 620 should give you plenty of power for overclocking and other things without running near peak load.
So you have:
Q6600 (~100w)
Hmm I'll try to find that page where I calculated with a psu wattage calculator. After inputing all those things listed, it came out to near 630~watts
also, Corsair's PSU finder recommends a 750TX
*shrug*
I would LOVE to not have to deal with buying a new PSU..
And I also asked Kyle and he wouldn't personally run it on the 620HX and when given the choice of 750w/850w, he said he'd rather do 850w.
I'm still getting opinions though
Well it is always good to have more headroom, so I would say if you were buying fresh it would not be a bad idea to go with the 750 or 850. But I think you could run fine on the 620 still is what I am saying.
Those wattages are all from the factory sites except for the video card, which does not list it and is more of an estimate.
Yeah, well the thing is that I'm planning on getting a 4870x2 and doing a WC setup with it too.
Only thing is, I don't want to plug it all up and go.. Boom.
And lose more components.
I'd rather be safe than sorry, especially with the PSU.
So the Corsair 750TX should be more than fine?
I'm thinking of trying to power a 4870x2 and a 4850 together, with the 4850 at idle probably 95% of the time as its only driving two monitors so I can have my 3x monitor setup. Possible? Or a bad idea? I like the modular design of PSUs and I feel like jumping to the 1000HX wouldn't be worth the extra power bill :X if its possible on the 620HX, though I want to know just how much load my HX620 would be taxed with....
Q6600 or Q9450
4gb ram 2x2gb sticks
6 120MM fans
4870x2
4850(never at any reasonable load assuming running the two monitors are always at idle)
Asus Rampage
1 DVDRW CDwriter etc
4x 7200 HDs that will probably be changed to one raptor, 2x 640GB WD drives
Anyone have any ideas? I used the xtremevision (which I know isn't recommended) but using two 4870s in CF at 90% system load pulls about 596 W
Note that a bigger PSU does not mean a bigger power bill. They pull only what they need.
That being said, some are more efficient than others.
As I have said before as well, the Corsair PSUs are great and deliver what they claim, unlike many others that dont and thus get our expectations set too low and thus we think we need a MONSTER PSU for a system.
Most of the time if you overload the PSU you are not gonna burn anything up but possibly the PSU. Usually it will just have a hard time starting and you might get BSODs or devices not functioning properly (HDDs not fully spinning up, Video cards artifacting under load, etc.).
For some reason I was under the impress that a 1000W PSU would pull a consitent 1000W regardless...it'd only just use what was needed but have the extra wattage in case. Not that I'd jump to a 1000W PSU, maybe a 750 or 800/850
Nope, they pull what they need.
For example, with a Kill-a-Watt meter hooked to my HX620 it was only pulling around 250watts with my rig.
Also note it is not the best to load a PSU all the way up and not the best to put barely any load on one as they become more inefficient. Best efficiency is around the 50-75% load area (of their rating). Thats why in your case if you did want the best power efficiency, it would be best to go with something like the 750. But the difference is not HUGE, on the corsair ones its usually only a few percent vs. optimal.
You can see some of the more efficient PSUs listed here:
http://www.80plus.org/manu/psu/psu_join.aspx
The percentage deals with how efficient they are in converter the power from the wall to your machine (so less efficient means more power is lots in the process of conversion).
Mmm...reading the link you gave grentz, would it be better to get an es-800 over a 1000HX just because of a higher efficiency (I know its small but hey, we're [H] members right? :D) Also, I read somewhere on this forum that when you get a 1000w+ PSU you have to check the ampere from your wall socket?
According to the [H] evaluation of R700, a system including a QX9770, 2GB of RAM, 3 Raptor drives, an optical drive, a floppy drive, a Koolance W/C kit, and two R700s in Crossfire drew about 550-585W(depending on the actual PSU efficiency; I used 80-85% as the range for my calculations). A 620HX could handle what you plan on doing without breaking a sweat. However, if your 4850 is only going to be driving two monitors, I would suggest swapping it out with a cheaper card like a 3450 so you can save a bit of cash and greatly reduce your power consumption as well.
Well I hope that whenever ATI decides to fix the idle issue with the cards, it'll be fine right? I got the pair of 4850s for 263 or so, so you can't really go cheaper ;)
Even if the idle issue is fixed, the card will still use a lot more power than a 3450, and there's no way to get around that. If you don't plan on using it for gaming, there's really no reason to keep the card since you'll have the 4870X2.
Depends on what load you have, if you look in the detailed report on the link I gave above you can see that PSUs are inefficient on the edges (too low a load and too high of a load) and most efficient in the middle 50-70% load area.
I asked a tech on corsair forums if it could run a hd4870x2 and they said from their testing there would be no problems whatsoever.
A similar question for my 610W PSU - PCP&C.
My build is similar with a Q6600 B3, 4 GB DDR2 RAM @ 1.8V, 2x DVD-RWs, 2x 150GB WD Raptors, 1x 750GB Seagate, X-Fi platinum.
I used a power supply calculator that claimed I needed a 750W PSU. I already own my 610W, so buying a new PSU would not be desired, but if I have to, I could.
Thanks!
Q6600 or Q9450
6 120MM fans
4870x2
Asus Rampage
Keep me in the loop on that, I am looking for a 3 monitor setup as well. Hopefully that will work out. Right now I have 2 of my 3 powered with 2x 4870's in CF.
Thanks!
You do not need a better PSU. I'd be surprised if your system used even 450W under load with a 4870X2.
The HX620 is a freaking beast. I've got mine loaded for bear with tons of HHDs and crap. It'll handle it without issue. It is a quality PSU - among the best for sure. Let it do what it was engineered and built to do.
Thankfully I found this thread.
I will be getting my 4870x2 on tuesday/wed, now will my HX620 suffice?
Q6600 @ 3.0GHz 24/7, 3.6GHz very often though
4x1GB HP2-6400
4870x2
2x Raptor-X
2x WD RE3 1TB
1x LG ODD DVD/RW
1x PCIe XtremeN Nic
8x scythe s-flex
MCP-655B
I will soon be getting a Xonar as well, so take that into account.
The answer to this post will mean a new PSU or not.
4x1GB HP2-6400
4870x2
2x Raptor-X
2x WD RE3 1TB
1x LG ODD DVD/RW
1x PCIe XtremeN Nic
8x scythe s-flex
MCP-655B
From what I understand the 620 and 650 are simliar in specs. I had a TX650 running my 4870x2 for a while with an OC Quad @ 3.4ghz and two HD's. So I would think you would be fine also. I had no problems.
You've had that PSU for ~1.5 years, no?
Shouldn't be much of a problem considering you would have just enough power, and capacitor aging shouldn't influence the overall result much either at this point.
You should be fine, however, as a matter of precaution, I would tend to favor upgrading the PSU because you will be pushing the upper limits of your unit. That, in turn, will reduce the life of your PSU as the level of heat increases, and efficiency decreases. Along with that, faster capacitor aging, although it still should not be much of a problem.
However, it is always good to have a bit more power than you would use. You would be fine for a year or two by pushing the unit that far, but I would change the PSU for something upwards of 700 watts for a measure of safety, efficiency, and peace of mind.
The end decision is up to you, but I would favor a new, higher wattage unit, instead of stressing out your current HX620.
I RMA'd my 1000HX (dropped dead after 1 week) and reinstalled my 620HX. I'm impressed at how well my 620 is handling the 4870x2. No slowdowns, lockups, nuthin' but smooth performance. I'll still swap it for the 1000 when the new one arrives, but can say from experience that the 620 seems to handle a 4870x2 just fine.
Glad to know, Im not prepared at this exact moment to buy a new PSU, but I intend on it within the next few months.
