Hi, I recently decided to upgrade my graphics card from a 8800gts to a 5850. When I received the card I put it in my computer and it would not post. All of the fans would spin and the 5850 fan would spin at 100%. I put my 8800gts back in and it worked fine.
I tried my 5850 in my roommates computer and the card worked just fine. I had previously thought that my power supply would be more than enough to handle my card just fine, so I came to the conclusion it was a motherboard issue (an asus p5k-e.)
I was thinking about upgrading to an i5 anyway, so I decided to go ahead and just upgrade. I received my new parts today, an EVGA P55 SLI mobo, i5, and 4GB of memory. I put everything together, and I still have the same problem. I've come to the conclusion that it's my power supply, since the only old parts in my computer are my power supply and hard drives, along with my case.
Should my hx520w be capable of handling my 5850? If so is there some problem with my power supply or is it some other issue?
Thanks.
Thanks.
