HWmonitor & 12v voltage?
FinalAura
I decided to run HWmonitor and was surprised at what I saw for the 12v rail on my corsair hx620.
Is this anything to worry about? Or is it just some weird glitch in the software or something. Just want to make sure. My system runs fine if anything.
Thanks for any insight.
No software PSU voltage reader is ever accurate. So ignore HWMonitor's readings.
If you really want to know your PSU voltages accurately, buy and use a digital multi-meter to monitor the voltages coming from the PSU. Follow the instructions for "Using a multi-meter to check voltages":
http://www.bfgpower.com/troubleshooting.html#DMM
of course your computer wouldn't even be running and executing hardwaremonitor if those numbers were correct.
