ghostface703
- Jul 24, 2013
I want to build a HTPC that will run hyperspin (with all emulators) and XBMC (with various applications like netflix, hulu, etc).
I want this HTPC to be portable so I can connect it into friends TV's and run any emulator/ play movies. I will be hooking up XBOX wireless controllers into the USB ports.
$400 max. I would obviously like to spend the least amount of money possible.
US, Virginia
Micro motherboard, cpu, htpc case, 1 TB memory, HDMI/AV hook up, a cheap sound card, not sure how much RAM but probably around 1GB ?
I do not have any parts that I can reuse
6) Will you be overclocking?
No
I want true HD 1080p/720i, but willing to lower quality if it brings total price down by a significant amount.
ASAP. I want to buy the cheapest parts available. I am willing to do ebay, craigslist sales.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 2.0. Minimal is key for this project. GPU if needed.
Yes, 64 bit. I'm going to be ghosting the program so that when pc is launched, XBMC will open
Thank you for your time and I can't wait to get started on this project !
US, Virginia
No
