Primary: HTPC
Secondary: Render Node
Tertiary: Light gaming
$700 total with taxes, will go over by $50 if it's worth it.
Canada. Using http://www.memoryexpress.com for my prices/availability.
All new system.
Case to fit in TV stand with PS3/Xbox, etc
CPU
Motherboard
Ram
HDD
BluDD
OS
Wireless KB/M
None
6) Will you be overclocking?
No, power consumption and noise is a factor.
Hooking it up to a 42" 1080p HDTV
First week of October
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No, 64-bit needed.
Hopefully this is in the right section, don't see a lot of HTPC build suggestions in the HTPC section.
I do quite a bit of 3D CG, mostly lighting and sims, so using up extra power out of any available PC will always be welcome. I will be needing a HTPC in the near future and would also like for it to act as a render node when needed.
These are the parts I was thinking. Links to Memory Express for local buying but, can order online. Not set on any part.
$129.99 - Antec New Solution Series NSK2480 Desktop Case w/ EarthWatts 380W Power Supply
$119.99 - AMD A6-3650 APU 2.6GHz w/ 4MB Cache
$99.99 - Gigabyte GA-A75M-UD2H w/ Dual DDR3 1866, 7.1 Audio, Gigabit Lan, 1394, PCI-E, CrossFireX
$49.99 - GSKILL Ripjaws X Series 8GB PC3-12800 Dual Channel DDR3 Kit (2 x 4GB)
$69.99 - Seagate 2TB Barracuda Green SATA III w/ 64MB Cache
$49.99 - LG CH10 Super Multi Blue 10x Internal SATA Blu-ray Disc Reader / Combo Drive, Black w/ Lightscribe
$119.99 - Microsoft Windows 7 Home Premium x64 (64-bit) SP1 DVD - OEM
$29.99 - Logitech Wireless Desktop® MK300
$750 after taxes, local pick up(no shipping).
If you have a totally different direction, I'm flexible. Don't want to break the bank so if you can cut the cost down, that'd be great. I am really just looking for Maximum CPU performance for rendering, while still being able to stream/encode(?) 1080p content and the ability to play Blu-Rays on a 42" 1080p HDTV. Gaming is a distant third.
Thanks for your time.
Primary: HTPC
All new system.
CPU
Motherboard
Ram
HDD
BluDD
OS
Wireless KB/M
None
No, 64-bit needed.
