NAS, HTPC
~$1300 CAD
Canada
Motherboard, CPU, RAM, PSU, hard drives, GPU
None
6) Will you be overclocking?
No
7) 7) What is the max resolution of your monitor? What size is it?
HDTV - 1080p
Within 2 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
6 SATA ports
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Will be using FreeBSD 9.1
Hey everyone,
At the moment, I've been using several external hard drives to store my media and a laptop to connect to my TV. It's getting to be a bit of a hassle so I'm looking to consolidate and build a NAS & HTPC combo box. I know the pros and cons of having both combined in one system, but the convenience of having everything all together was the deciding factor for me.
Ideally, I'd like to go with FreeBSD and XBMC for a couple reasons: 1) ZFS; 2) I'm familiar with XBMC; and 3) I found a handy guide at http://www.overclock.net/a/freebsd-htpc-and-home-server that seems to do exactly what I'm looking for. I've never used FreeBSD or ZFS before, so this will definitely be a learning process for me.
Anyways, on to the hardware - this is where I may need some advice! I have picked out the following parts:
Case: Fractal Design Refine Mini - $100
MB: ASUS M5A97 R2.0 - $100
CPU: AMD Bulldozer FX-6100 - $120
GPU: Gigabyte GeForce GT 610 - $45
RAM: Kingston KVR1333D3E9SK2/16G 16GB 2X8GB Kits - $152
HD: 5 x Western Digital Red 2TB - $111 each ($555 total)
PSU: Seasonic M12II 520W - $83
Total cost for the selected parts is about $1,200 CAD.
My rationale for the above parts is as follows:
1. MB/CPU - ECC memory is preferred and AMD has wider support for ECC. By going with AMD, I won't be limited to Intel server grade motherboards.
2. RAM - 16 GB ECC RAM selected as ZFS performs better with more memory.
3. GPU - Nvidia GPU chosen for VDPAU support.
4. HD - WD Reds chosen as they were designed for home NAS use. I already have one WD Red 2 TB and so will have a total of 6 for RAID-Z2.
I'd appreciate any advice regarding this build. Are there any obvious incompatibilities that I have missed? Thanks!
NAS, HTPC
~$1300 CAD
Canada
None
No
HDTV - 1080p
Within 2 months
6 SATA ports
Hey everyone,
