My current HTPC build is in an Antec P180B case - obviously not an HTPC case, but it is what I had to build in at the time. I have a BACH case that the EVGA Classified E760 motherboard would not fit in, so I was left with the Antec case as my last resort until I found something that would fit the motherboard.
When I upgraded "Frank", his "old" parts were sent to the HTPC build. I had to convert all the parts back to Air Cooled as opposed to the water blocks I have for all the GTX 285's, the Classified Motherboard, etc because I was missing a CPU block, the radiators, and a pump. I am now considering an HTPC case that I can install all this in with water cooling in mind. I will be purchasing an external radiator, pump, and CPU blocks so I can make this happen.
Here is basically the gear I need to shove into a HTPC case:
6 HDD's = 10TB SATA II Hard Drives
EVGA Classified E760 Motherboard water blocked
4x GTX 285's water blocked (3 SLI, 1 PhysX)
1x Core i7 975Extreme Water blocked
6GB (3x2GB) Mushkin Redline
Blu Ray Optical Drive
DVD/CD ROM R/W Optical
The only thing air cooled will be the HDD's and the RAM, everything else I will or already do own the water blocks for. Here is a picture of the current build:
What I plan on doing is building an external cooling solution here:
I figure I could mount the reservoir, pump, and radiators on the backside of the cabinet, run my tubing in/out of the HTPC, so the HTPC will not need to also incorporate the water cooling system as I will do this external.
This cabinet is a Standout Designs Horizon N702 with the back extenders as well as the cooling options installed. I believe with the air flow capabilities of this cabinet combined with the water cooling mounted external for the hotter components, the HTPC case I get will need to fit in this unit and be mainly concerned with air cooling the RAM and HDD's.
So with all this in mind - any suggestions on a good HTPC case that I would be able to put all this gear in, be able to run tubing in/out of, etc? I would really like if it came with some kind of control panel or display panel that works on the front of the case and that if anything software related can operate with W7 Ultimate 64
