id like to do mini-itx if possible, or at least m-atx in an htpc. i need a good match for this. i dont know anything about mitx or matx at all, so i need some pointers. any suggestions? any setup is ok as long as it is decently small and will play HD video without a problem. links to fs/ft are preferred, as im looking to keep this stuff cheap as posible.
also need a low-profile power supply of some sort to run everything.
ok not sure whatll help but heres the questions answered:
just all types of movies, transferred over gigabit, in 1024x768
whatever it costs, cheap as possible though. probably no more than $200
3) Where do you live?
seattle, would like to buy used off fs/ft though
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
psu, mobo, cpu, ram, pci riser card
just monitor and case and this backup card i have.
6) Will you be overclocking?
just as much as the psu, cpu, and board will let me
1024x768
over the next couple months. no rush.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
gigabit and sata. some usb ports i guess.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
yes. xp home 32 bit.
1024x768
