luckylinux
- Mar 19, 2012
I would like to hear some opinions about an HTPC build I'd like to do.
I though to use something like the Silverstone GD01 as the case and something like a Bequiet BN186 - 400W 80+ Gold (could you suggest others please? I love corsair AX-7/850 series, but here it's a bit overkill to say the least), but from there I have absolutely no idea what to put in: I'd really like a board with LOTS of PCI/PCIe slots (6 or 7, therefore a ATX board).
I wanted to host my media server (Mythtv under GNU/Linux) in VMWare Esxi and doing therefore some virtualization as well. Options are therefore a bit stretch:
a) Going with AMD (I already own a Athlon X4 setup on a M4A89GTD-PRO - maybe that's enough - that board supports FX processor as well, though it's a beta BIOS )
Therefore buying a new FX-6100 / FX-6200 / FX-8120 CPU and something like an ASUS M4AX99-EVO which supports ECC-Memory and virtualization
b) Going with INTEL (which has plenty of possibilities and inconvenients at the same time)
- ASUS P8BWS + Xeon E3-12xx series: dual integrated INTEL NIC, supports VT-D ? (I hope since it's designed for Xeon ...)
- Any Z68/Z77/H67/H77/P67 board doesn't AFAIK VT-D
- The only motherboards supporting VT-D for socket 1155 are Intel's and some Supermicro's, though they're (relatively more) expensive, and some INTEL entry level microATX motherboards using non-K processors (but I'll eventually run out of PCI/PCIe slots very soon)
Since INTEL doesn't support ECC memory for non-Xeon processors, I'd normally go with AMD, but since this will be ON 24/7 power consumption is a big deal, more that it is with ECC memory. Maybe those Ivy-Bridge processors can solve this
Any thoughts would be appreciated. The Athlon X4 doesn't make a very good virtualization CPU, and I don't think it can handle recording of video streams without too much problems.
I plan on adding an entry video card as well (currently I already have a GT-430, GT-520, HD-6450 and HD-5450 to choose from ).
Budget ... let's say ... it's not so tight ... better have something which will (hopefully) last long.
Planning on using a USB stick for Esxi to boot from, then using SAN/NAS for storage. No SSD/HDD therefore. Better keep the budget under 650$ (the GD01 case is 130$ by itself) though
BTW, do you know how they call these things to split a DVB-T or DVB-S cable into two? I bought one and then realized that it was actually a filter splitting two different signal frequencies. Recording on two separated cards would be very good
