Hey all,
I am working on planning out a HTPC that will mainly be used for DVRing TV shows I miss while at college.
I have the general specs for the computer down with the exception of the TV Tuner card (Or equivalent, not sure if I am using the proper name). I will further refine/post the actual computer specs after I figure out how much this TV Tuner card will cost. I am not looking to spend a lot of money on this build, but I am willing to spend the extra money for a quality tuner card.
We currently have an older 50" HDTV (Available inputs are Coax, SVideo, Composite, Component, and DVI). We will most likely be upgrading to a new TV before the end of the year though.
Here is what I have/looking for:
- I have a Comcast HDTV Box. (It only has a single tuner though, I wouldn't be opposed to getting a dual tuner box or getting another single tuner box for this build if it is necessary).
- I would like to be able to record from HD channels (Syfy and Discovery). But I understand if that isn't possible, or if it would cost a significant amount more.
- The channels that will be recorded the most are: Syfy, Discovery, CBS.
-Internal or External doesn't matter to me, whichever will allow the best quality picture.
Thanks very much.
Edit, I forgot to ask: Will a 'Hauppauge HD PVR' essentially do everything I asked above? If so, would a dual tuner (or another single tuner box) Comcast HDTV box be required then?
Thanks very much.
