I'm in need of a NAS system, but also want to eventually use it for my HTPC backend, so I want to dual-purpose the machine for NAS and HTPC storage.
So, I'm trying to determine my parts list, but wanted to run a few things by everyone to make sure I'm not completely off-base.
I have Comcast, but I'd like to not be limited to my current TV provider in case I change providers when I build a new house in a few years (or so is the current plan). I bring this up because I've read about some tuners that have trouble with certain providers' encoding schemes. I don't need a tuner right away, but if I do get one, I'd like it to be able to pick up any standard cable channel that a cable-ready TV could pick up by default. Eventually, I'd like to add another tuner with a cablecard for digital (This will not be co-located with any of the TV's)
Is PCI express x1 pretty much the standard for tuner cards?
For the case, i'm planning to do a rack-mount case like thus: http://www.newegg.com/Product/Product.aspx?Item=N82E16811321004
I don't have a rack yet, but I plan to eventually and I can make room easier for that type of case.
For the CPU, I was looking at a Athlon II X4. I was thinking this because of wanting multiple tuners. Is this overkill? sufficient? Assume that I may eventually want an HD tuner.
Motherboard - This is where most of my questions come in. I don't know if I want to set up something like RAID 5, or JBOD. for the OS, I was planning to install Linux on a CF card (like 8 gig or so) and run it off of that, then have the hard drives dedicated to data. I'm trying to think about the best way to set this up. I can get a mobo with onboard RAID, but will I lose the data if the mobo dies and i get another one? what if it's a different mobo? can i retain the data then? If I go with a RAID card, the cheaper one's I've found are PCI-X, so that basically limits me to a server mobo, which drives costs up. I was looking at this (http://www.newegg.com/Product/Product.aspx?Item=N82E16813130223) but it doesn't have any onboard video, so there's another cost. Plus it only has 1 PCI-e x1 slot, so I may be limited to to a single tuner. However, it was the only result in my search that had at least 8 SATA ports and did RAID.
moving on, how much RAM would be necessary if using 2 tuners? 1gig? 2? 4? what if I added a 3rd tuner long down the road for HD?
lastly, the HDD's.... I'm looking at the Samsung EcoGreen drives in 1.5 TB capacity since they are cheaper per GB than the 2TB drives currently. I've always had good luck w/Samsung, WD, and Seagate.
Final comment: I'm trying to make this thing with low power, but also powerful enough to do the tasks I need it to do. Knowing that this will only feed frontend systems across the network, I assume all of the decoding power will be necessary on the frontend, not this backend, correct?
Hopefully my questions make sense.
Thanks.
Thanks.
