HTML Popup Formatting
JC724
So I have popup I created for a button.
I want to have the text "xXyY" and a X closing symbol right on the side of it. Both at the top of the pop up box with a horizontal line under it.
I was able to put a horizontal line under it and the "xXyY" and X above it but I can't get them side by side.
modi123
I am not quite following. Do you have your HTML snippet or a screen shot?
Absalom
HTML snippet or it's guesswork for us.
I take it you are trying to get a singular horizontal line under both the text and the X symbol?
If that's the case, then don't use the underscore (<u>) formatting. You'll need to use something like a line break (<hr>).
If you use something like bootstrap, you can create a 2x2 grid and then stick the <hr> in the bottom row container and have it span both columns. This would allow the line to span under both elements even in a variable text width scenario.
JC724
Sorry, I didn't think about that. This is a screenshot. I am trying to figure out how to get the X on the same line is the "Over Time...." and on the right hand side of it.
I am still learning HTML/CSS. PopUp_NotFormatted.png
Damos
Is the X supposed to be clickable and some function works after clicking it? Where is is coming from?
Have you looked at w3schools?
If it's just for show: <p>Over-Time Approval Confirmation &#10060;</p> or a <h> tag like so: <h3>Over-Time Approval Confirmation &#10060;</h3>
modi123
Good ol' float left/float right on divs should work.
ex:
HTML:
<div style="border: 1px solid black;width:300px;height:100px;">
    <div style="float: left;padding: 5px;">Over-time approval confirmation</div>
    <div style="float:right;border:3px solid red;padding:5px;">x</div>
</div>
JC724
It is click able but for me I don't have to control the functionality behind it. I am just working the UI for visuals
JC724
ex:
HTML:
</div>
ok I will try this
grasshoppa
Doesn't necessarily answer the question, but jquery ui is a good framework to start with. To get a dialog box it's as simple as
Code:
<div id='dialog'>
text of dialog box
</div>
Then call it with your jquery:
Code:
$('#dialog').dialog();
Check it out: https://jqueryui.com/dialog/
