Hi,
Am starting to hook things up in my first build.
What is the optimum direction to point the cooling fan through the Ultima-90?
I'm placing 2 120-mm exhaust fans at the top of the case. Of course there is also a factory-installed 120-mm exhaust fan at the rear (top) of the case.
So, I'm thinking that placing the heatsink fan to blow directly upward will be more efficient in cooling than having the heatsink fan blow toward the rear of the case. This should take the hot air from the heatsink in more of a straight line (and heat rises) out of the case.
This is how I installed last night.
If it's better, for some reason, to point the heatsink fan toward the rear, I can turn the cooler to point in that direction instead.
Suggestions?
Steve
- IP35 Pro mobo
- TJ09 case
- Ultima-90 heatsink and 90mm fan
Suggestions?
Steve
