HSF Comparisons... Core i7 build up...
loft
Jumping right into it. Building a core i7 system... Antec Mini P180 for the case... tossing the idea back and forth as to which HSF to use.
Currently I'm looking at...
Noctua NH-U12P SE1366
Scythe Ninja Mini
Will the Noctua fit in the Mini P180?
Being mindful, I will be using three Noctua NF-P12 fans (2 Intake, 1 Exhaust) and the stock 200mm fan in the top of the case.
Sound/db does not matter as I have a fan running in this room at all times...
there is a good thread on best cheapest best most expensive HSFs
it is on here somewhere, I will post if I find it
best cheapest: xigmatech
best most expensive: megahalem/TRUE
am i rite?
He might be limited by the size of teh case... Though if the pricey Noctua heatsink he mentioned fits, then the cheaper and equally good Xigmatek S1283 will fit as well I believe.
Price is of little concern. I only need low maintenance lol. But ya... no idea what will fit in the mini p180.
Price is little concern.. I would suggest water cooling it then. Youll spend a little penny on a good HSF combo anyway, spend just a few more dollars and do a simple water cooled solution.
Get a GOOD mobo with GOOD mosfet and chip coolers too.
Water cooling is higher maintenance than what I'm looking for. Plus, there aren't very many micro-atx options out there for motherboards.
