HR-05 install maybe not going so well
blade52x
So I installed the HR-05 today because I was having stability issues above 380FSB and thought it may have been due to the "burned my finger when I touched the touch heatsink"... So I put in the HR-05 today. I used AS5 on top of the NB (thin coat). All seemed ok... at first.
I was in Windows for about 5 minutes and the computer restarted. It goes past the Windows loading screen and then nothing. Just a black screen. I turn it off, and I have the cold boot issue. It just cycles on and off. I let the computer sit for about 5 minutes and then turn it back on. It boots into Windows and freezes.
I touched the HR-05 and literally felt like nothing. I touched the bottom of the heat pipe, and I didn't really feel any heat. The top of the heat pipes did have a very small, and I mean small amount of heat.
So I think I may have bad contact. Does everyone use the cushion pad? I think this may be the problem. I'm thinking maybe it is too high and I'm not getting the right contact. However, with it off the heatsink feels pretty shaky and moves around very easily.
Don't really know what to do right now. And all this was running at 274fsb, not 300, 333 or 400.
Can't even tell what my temps are because the DS3 does not report NB temps.
Nevermind, I removed the cushion, and everything seems good now. Hopefully nothing shorts because I'm not really sure if I really need or not.
Your are good, no worries. That was a thermal pad that sooner or later would have melted some and acted as thermal paste. They include it for people that dont have any thermal grease on hand. The AS5 is much better and you dont want both. You did the exact right thing.
No, the HR-05 has a square cushion that goes around the outside edge of the contact surface to keep it from moving around.
To the OP, whatever works for you, I had the exact opposite problem. Installed with no cushion and got random reboots and crazy stuff all the time, then added cushion and was great.
Yeah, that pad is kinda worthless. If you want better stability, some RTV helps a lot. Permatex Ultra Black...
Ahhh Doh! the rtv is a nice trick.
