I got this monitor a couple weeks ago, but I'm having trouble with it:
1) the monitor has the wrong color profile under win7. On a TN monitor, if you look at the scrollbar of Internet Explorer (for example)it is made up of a checkerboard pattern of gray and white squares (6-bit instead of 8-bit color channels) rather than a single solid color. For some reason when I switched from my TN monitor to my zr24w, this checkerboard pattern remained. I've uninstalled the drivers of the previous monitor, installed the color profile of the zr24w and manually tried to fix things, but nothing has worked so far...
This problem doesn't occur with a newly installed winXP partition, but I'd rather not have to reinstall win7 to fix this...
Any ideas?
2) my monitor has horrible uniformity (at least according to my expectations).
Here is the link http://vfzeqw.blu.livefilestore.com...dJ_rkbVWXmtyJnmtVPibxkPN4shA4G/595.jpg?psid=1
This picture should be viewed portrait (with the left side at the top) but for some reason the picture got flipped when uploading...
Be at least 6 feet away when viewing so you can see the lines... basically it is black and white lines running up and down the screen. On a white background monitor looks horrible. I think in person looks much worse than the jpeg.
Should I RMA it or is it normal?
Thanks![]()
I have no visual anomalies like you describe on any of my screens. I would RMA it if it bother you that much. It doesn't cost you anything besides shipping and some time eh?
That picture was taken at 15% brightness, my current settings areekaggen - did you try turning down the brightness yet? Lots of calibrated settings I've seen in this thread have the brightness at or near 0%. Eg. tftcentral ended up with it at 7%.
I just got twin ZR24w's from Amazon. These are my first IPS monitors. I'm coming from a Samsung ToC T220 after I decided I couldn't stand its vertical shift & bad colors.
The one thing that really bothers me is the white glow on dark backgrounds, even when viewing dead on from 2.5ft away. It's most noticeable in the bottom left. Lowering my head seems to lessen this, the glow is VERY sensitive to vertical angles and becomes huge with a change of +15deg.
(shutter slowed down which slightly exaggerates the glow brightness)
Taken at 2.5ft
Is this a big problem with the ZR24w's or did I just get a bad batch?
Saw it on BH for 375!!! I might buy two.
http://www.bhphotovideo.com/c/produ...kard_VM633A8_ABA_ZR24w_24_Widescreen_LCD.html
too good to pass up. ordered.
anyone want to buy a flawless 2209wa?
I would kinda get it but its really not good showing blacks.
That depends on the settings you've adjusted the monitor to, and the context in which the blacks appear. A pure black screen is where the monitor really shows it's fault. But how often do you sit and look at a plain black screen? IME, the blacks are great, so long as the only thing on your screen isn't pure 0,0,0 black.
How is this for a gaming monitor?
shipping confirmation from MacMall.
Have tracking number, but PayPal hasn't been charged. weird.
BTW. OOS from them already.
I'm happy I didn't order now...
what's return policy of B&H like?
about $20 more from Amazon, and easy returns with them.
My order shows as shipped, but MacMall's credit department left a message saying they want to talk. I'll call them tomorrow.
