HP w2408
rugid
Got my 24" mirror yesterday, shipped from wallyworld. You can check the specs at HP.com. I'm not going to try and do a critical review, but here are some observations for anyone not put off by Brightview (glossy) screens.
Glossy screen - Who's afraid of their own reflection? Hasn't bothered me a bit, and I sit with two windows behind me. YMMV.
PQ - above all, the color is incredible, bright and clear from the front. Colors do change hue from the sides, top & bottom. Presets for color are good, though "gaming mode" baffles me; it causes the screen to wash out. Unusable for me. Text is sharp and I don't notice any ghosting. Wife and I spent hours looking at photo's we've seen a hundred times on the our 19" westinghouse; just because they looked so much better; they looked real.
Backlight & pixels - Some small amount of backlight bleed, but looks even and not distracting to me. Zero bad pixels.
Mount - solid with cable guides. Not a lot of height adjustment though, a pain if you want to use the screen rotation feature.
Other features - light sensor (have not noticed it working, which may indicate it works well.. or not). USB ports on left side. Rear facing speakers, which I'm actually using when I don't have a headset on.
Looks - Bezel is a bit wider than I'd like and there's a strange cowling around it. Almost makes the front look like it's sagging out of the case.
Conclusion? More than I wanted to pay, but I figured if I didn't like it, walmart is an easy return. I had a samsung 24 from costco, but it just didn't "look" like $500. If you want the best gaming monitor, this probably isn't it, and no clue if an Xbox will hook to it (doubt it). Also not the best deal for the screen realestate.
But for me, it's a beauty and it stays with no regrets.
Hopefully, someone else will do a more technical review and post some pics.
Rugid
Does that model have a TN panel? Glossy is great if you ask me but I'm also baffled by so called "gaming modes" that simply kick the brightness up to max. On my NEC 20WMGX2 I've found that "photo mode" is the only one that doesn't do this....I guess monitor makers think pc gamers only play Doom 3. :p
.... If you want the best gaming monitor, this probably isn't it, and no clue if an Xbox will hook to it (doubt it). Also not the best deal for the screen realestate.
Rugid
Have you tried any games in it? I wonder about this, it may be just fine for games, please someone post that has the monitor and plays games. Someone out there, please?
tybert7,
I play Warcraft on an E6600, 2GB ram, and GeForce 8800 gts. Plays great with no blurring or noticable input lag. WoW looks "wow" on this monitor because there's so many cartoon colors and it isn't too hardware demanding.
I don't play twitch games, so I'm not the best judge for how the monitor perfoms under those conditions to a critical eye.
Rugid
The Samsung 245bw isn't calibrated well at all from the factory, in terms of gamma and brightness settings the hp 2408 is probably setup a lot better from the factory.
How does the HP W2408 compare to the Gateway FPD2485W/2185W as far as component inputs are concerned? Does it have a PIP feature?
I'm interested in hearing more about this monitor, in general, especially for gaming purposes.
I've had several people I know, who know I'm on the prowl for a 24 WS LCD, pretty much freak out and do cartwheels begging me to see this thing.
Amazingly little info about this monitor out there. It must be brand new or something..
I saw it for sale at Best Buy for nearly a month and I'm in Canada. The monitor is fairly new but has been available for a little while. It isn't the most affordable display out there and might take some time before people start posting their experiences.
It seems pretty decent at its price point, but that extremetech review I added to my previous post concerns me a bit.
I'm reading it now. Thanks for the link.
