Hey,
I'm thinking about those 2 monitors. I know which one is better, the problem is the price DOES matter and the HP is exactly twice as much expensive as BenQ. So here's what I'm going to do:
1) Find out whether v2400w fits my needs or not
2a) if it does, I'll take it
2b) if it doesn't I'll probably take LP2475W
What I need?
- 23-24"
- HD support
- great for PS3 games
- good for Blu-Ray movies
- good looking
- good for casual movies played on my computer (Mac mini)
- good for daily computer tasks
- the ability to connect both Mac mini and PS3 at the same time, great if it will change the input automatically then one is turned off and the other is on
So, will the v2400w do what I need or you think I should pay (TWICE AS MUCH) for 2475? Thanks in advance
What I need?
- 23-24"
- HD support
- good looking
