dynamis said:What video card are you driving the L2335 with? Is it possible to run all-digital DVI-I at 1920 x 1200?
From the specs I have seen you have to run DVI-D with the 24-pin dual channel to get the video bandwidth required to produce 1920 x 1200 at 60fps.
I thought that DVI-I maxed out at 1600 x 1200 in 4:3.
Is anyone out there running FarCry at 1920 x 1200 on an L2335 with an ATI X800 on a PCI Express graphics port, all-digitally through DVI at 60fps?
Pffft. Riiight.
1920x1200 (noAA, 4xAF) on a 9800XT, AGP 8X, all digitally through DVI at maybe 20 fps.
See this white paper for info on DVI-I and DVI-D: http://www.proxima.com/downloads/pdf/DVI-WhitePaper.pdf
I read the white paper. I don't care about Far Cry. But what of the HP documentation that says the maximum resolution is 1600x1200 with DVI? Is this more bogus documentation?
It sounds like canislupy is running this using DVI at full-res. Whether application/game X works or not is a different issue, no?
So is the HP doc wrong? The whtie paper was useful, but seemed to tell me that DVI-D would be required, and the specs don't say anything about DVI-D. Also, I'm a DVI newbie. Will purchase a DVI card to get the most bang out of this display (and to run dual inputs, DVI & VGA), but the manual says this:
"The video mode supported by the DVI-I connector is determined by the video cable used. For digital operation, use the DVI-D to DVI-D signal cable provided. For analog operation, the DVI-I to VGA signal cable must be attached to the DVI-I input."
This makes it sound like the beast supports DVI-D to DVI-D, which would allow 1920x1200 digitally. Did I read this right?
Can someone clarify modes of operation? And what cable does one need? (Or is everything bundled?)
Brendan
