dave_graham
- Jun 17, 2004
BNOYHTUAWB said:That hp L2335 is one fine big display!
... just sometimes it start to make soome noise ...
u then just TURN UP THE VOLUME ;-)
what?
cheers,
dave
jeffmace said:Last night I tried hooking my XBOX up to the L2335 with the HD adapter and component cables. I set the XBOX to turn on the 480p, 720p, 1080i in the XBOX dashboard. Honestly I am extremely disappointed in the quality of the picture. Am I doing something wrong? Madden look terrible. There was nothing sharp about the image whatsoever. Yes I played around with the zoom settings on the monitor to see if that helped.
Hopefully someone can tell me something that I forgot to do to make it look better, because I don't see HDTV quality at all with the monitor.
jeffmace said:Well, this Friday, I have an appointment with Cablevision to bring me my HDTV box to view HDTV on the L2335. Is there any advice on how to hook this up and get the best picture possible? From the online manual, it appears that the HDTV box has DVI out, is that the best way to use this. I have a 4 port KVM switch that will allow me to use the DVI option. Otherwise I can still go the component cable route.
Any advice is welcome!![]()
jeffmace said:dabomb, thank you for your reply. I guess I will try the XBOX hookup again. I don't know why it looked so bad to me, but instead of everything look razor sharp like others have stated, mine looked really jaggedy and dull. There was nothing good to say about it at all. Maybe the new Microsoft HD adapter I bought was defective, or maybe the cables that came with it. I guess I will pick up some Monster Component cables to see if that does the trick.
nextwish said:I live in Australia and I just got my L2335. When i first turned it on, i was very pleased, no dead pixels and my 9800 XT ran it in 1920 x 1200 DVI with no problems whatsoever.
I was extremely happy with it for about 4 hours until suddenly while using for web browsing and entire strip of dead pixels - spanning the entire screen from left to right - suddenly appeared. Basically a whole line of black pops up and nothing i can do will make it go away ... i tried changing to the VGA connector, shaking it, applying pressure to the screen etc. ...
It looks permanent. I believe this problem was noted previously by someone else, but their problem was a thick strip of pixels and came straight out of the box. My issue is just a single line (1 pixel thick) spanning the whole horizontal left to right of the display and it only arose after a few hours of usage. darn .......
Now i gotta do the replacement dance with my dealer
Dungeon_Master said:After fighting with this heap for the last few days I have decided that this monitor isn't worth the extra money I paid for it, versus the 2335. I have not been able to get rid of the "pan studder" that is present on any component video source. After several attempts to get someone at HP support that DOESN'T own a quickie mart I finally figured out that they have no clue.
All of the "indian" support reps had no clue it was a monitor. I kept giving them the model number but they insisted that I give them the model number of the tower. Um, hello Ghandi but I bought a monitor and NOT a CPU! After hanging up on 2 of the in search of a person with a clue, not to mention a more understandable accent I finally got a guy with an American accent. However, my joy was short lived as this guy had about as much of a clue as the rest of them. This guy tells me that HP only supports the PC input and not the Component input. Later on he tells me he really don't have a clue because he wasn't "trained" on this model.
I hope everyone else has better luck with HP support than I had. Its just too bad the monitor doesn't live up to what its supposed to do.
I'm glad that Costco has a no questions asked return policy.
Bummer.
)SHAGGY( said:mmm... awfully quiet around here....![]()
MrJamela said:How big a difference is there between the two modes? (DVI and VGA?)
Jaime
welcomerain said:concerning the viewsonic:
UltimaParadox said:I am guessing you prefer the HP over the viewsonic then. I had been looking at both monitors.
welcomerain said:incorrect. i love my viewsonic EVEN though it's slower. then again, i am also enamored by widescreen goodness.![]()
well, i was complaining because i had to revert to analog on my viewsonic, since i do not have dual dvi-out--yet. otherwise, i'd still have two-somes with it and the hp.
UltimaParadox said:Come on give me a straight answer...., I can't make up my mind. And I really only need one monitor.
MrJamela said:I asked Dave this question, but I'll post it here as well.
I would want to use this monitor for two separate machines (Mac and PC)...what is the best way to hook up both computers to the monitor while maintaining good image quality?
I was looking at DVI KVM switchers, but they are really, really expensive. Has anyone come up with an affordable solution to this problem? It's bad enough I'll probably need to buy new video cards....
Is there a way to hook one up as DVI and the other as VGA?
Jaime
jeffmace said:Have you seen the new 26" and 30" monitors from DELL. They look real nice and they are HDCP compliant. I think they are only 25ms but they are set for HDTV.
DELL WEBSITE
jeffmace said:This is the 4 port DVI KVM switch I use from Belkin. Here its $226, but I am sure there may be some places that have it cheaper. I don't exactly know what price range everyone thinks is expensive or not. I think this one works well for the price.
Belkin 4 Port KVM - DVI Switch
MrJamela said:I just looked at that switcher.
Perhaps I'm not understanding completely, but that switch and all of the ones like it (even the really expensive ones) don't seem to support resolutions beyond 1600x1200 using the DVI. Is this a problem for the 1920x1200 resolution of the HP?
Jaime
jeffmace said:I own this switch and believe me, it does 1920x1200 just fine on both my Mac and PC. I run a BFG 6800GT OC on my PC and it looks wonderful expecially Far Cry. I love it!
jeffmace said:Does anyone have more info on HDTV and the HDCP compliance with this monitor. Does it really effect it at all?
jeffmace said:So as long as you use the component cable hook up, you should be able to view everything just the same, but I guess not as high quality as the DVI port. Is this correct?
