Hello!
I'm putting together a PC for a friend, who will use it for Lightroom, Photoshop, Premiere and ocasonally for AfterEffects...
My budget is limitted to 1200 and this is what I've put together:
What do you think?
I choose HD7870 instead of GeForce GTX770, since that card is also supported by Adobe and costs a lot less. It al so has support for OpenCL 1.2 and nVidia only supports OpenCL 1.1.
I also choose i7-4770k so I can overclock it a little if I decide to and squeeze a little more out of it. Also, Mugen should be enough to cool everything.
The two Seagate HDDs will be put together in a RAID1 configuration to give some security to data.
700W PSU should be enough for everything.
What do you think?
MAtej
- Crucial Ballistix Sport 16GB DDR3 Kit
- be quiet! Pure Power L8 700 Watt
- Fractal Design Core 3000 schwarz
- 2x Seagate ST2000VM003 2TB Pipeline
- Samsung SSD 840 EVO Series 250GB Basic-Edition
- Scythe Mugen 4
- ASUS HD7870-DC2-2GD5-V2 2.0 GB OC Mid Range Grafikkarte
- Gigabyte GA-Z87MX-D3H Sockel 1150 ATX
- Intel Core i7-4770K Boxed inkl. Lüfter
What do you think?
What do you think?
MAtej
