Hows my build looking?
spear33
Just everyday use with some gaming. Nothing too intensive, just enough to run newer games.
I'd like to keep it under $550 after tax and shipping, but I'd go higher if necessary.
3) Where do you live?
Pennsylvania
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything but peripherals and case.
Lian Li PC-65
6) Will you be overclocking?
Most likely not.
19" @ 1280 x 1024
Within the next month, but as early as this week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing too specific.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
Currently I have
Combo
AMD Phenom II X3 720
GIGABYTE GA-MA790X-UD4P
$218.99
SAPPHIRE 100245HDMI Radeon HD 4850
114.99
Western Digital Caviar Black WD5001AALS 500GB 64.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 47.99
LG Black DVD Burner 24.99
BFG LS-450 Power Supply 49.99 (after promo)
Subtotal: $521.94
Shipping: 8.55
Promos: (13.80)
Total: $516.69
Its been awhile since Ive done this so let me know what you think as far as compatibility, price/performance, and any other suggests you have.
In addition to HardwareGuru's excellent advice, you can shave off $3 by going with this Corsair RAM:
$45 - Corsair TWIN2X4096-6400C5C2 x 2GB DDR2 800 RAM
