Jimmy Swanson
- Jul 16, 2004
I'm new to all of this overclocking stuff and am looking for some feedback. After some initial issues (bad stick of Corsair ram*frustrating*) I've been playing around in the bios. I've been trying to learn more about all of this to figure out exactly which settings to change. All I've done so far is changed "Cpu Host Frequency" (that's the FSB, right?) to 350Mhz, PCI Express to 100Mhz and System Memory Multiplier to 2.0. It checks out to be stable at 3150Mhz and while instead using 300Mhz at 2.5 as well.
My question is, where do I go from here? I tried raising the FSB to 375 and 400 and the settings don't stick after reboot. It's not that I don't think going from 1.8 to 3.1 isn't great, I'm just trying to learn more about all of this. Such as, I read a lot about memory timings or running at 1:1 ratio but I don't quite know how to address such settings as I don't see any options. Also, is it true that Intel TAT reports temps over 10 degrees higher on the 4300? They are at least always 10 over CoreTemp's readings. I'm currently at 3.1Ghz and 51 degrees stressing with Orthos so says CoreTemp. I think the only heat issue I have currently is the Northbridge because it's ridiculously hot.
