How to Un-RAID an HDD?
sinn98
I figured this would be easy but it won't let me format my drives...
A long time ago I had 2x250gb HDDs running in RAID0. I have a new PC and those 2 drives have been sitting in my closet now for some time.
I wanted to use one of them to compliment my main HDD as a backup drive. So I figured I could connect one of the disks, boot into Vista, and re-initialize/re-format the disk in Disk Management, just like we do for any new or used HDD, right?
Seems I was wrong. BIOS and Disk Management see the disk. But Vista won't let me initialize (get the "Cannot find the file specified" error) or reformat (because it won't initialize).
The only thing it reads is the disk size, listed as being 500gb instead of what it really is, a 250gb, a sign that it's still in it's old RAID self...
So my question is, how do I re-use this once RAIDed disk as just a normal HDD?
Thanks in advance.
if this hard drive was on the same board, or the same series of raid controllers, you need to go into the controller menu(after bios) and chose "delete raid array"
you can use dban, wd diag or other hdd utility to erase the drive(fill with zeros) that should let windows init and format it
You may need to restore the Master Boot Record or MBR for short. The RAID array may install a custom MBR preventing Vista from being able to initialize the drive.
Don
try diskpart on the Vista machine from a CMD prompt, its worked for me several times on stubborn drives.
diskpart <enter>
list disk <enter>
select disk ? <enter> (? = disk number you want to erase,..be sure!)
clean <enter>
exit <enter>
Thanks for all the advice, I <3 HardForum...
The first reply worked for me, I didn't think of setting my BIOS back to RAID mode since my system was non-RAID, but I did and sure enough I was able to choose "Delete RAID array" on the affected drive. Vista formatted it successfully now...
Thanks again.
