How to replace/fix NZXT Source 210 audio jack?
DarkDubzs
So my headphones jack on my case has stopped working, when i plug in my headphones all the way, only one side of them works, and if i leave it halfway in, both work but it sounds weird. I have a replacement of that part that has the jacks and usb ports, but idk how to replace it and there is no help online. Im not sure where i have to try to pry or pull out the part or what really to do or even start. Its an NZXT Source 210 case (not the elite version). It looks just like this:
index.php
Any help on how to replace this or even just how to fix the headphone jack problem?
BUMP
any help please? Anyone had experience with a problem like this or worked with an NZXT Source 210 case?
The front cover has an opening at the bottom of it. Grip there and pull up so that the front cover just pops out. Then just remove the front cover of the case, unscrew and disconnect the audio/USB board, screw-in/install the replacement board, and put back the front cover. Fairly easy process.
Also, please don't bump after only an hour and 40 minutes. Six hours between posts is the forum etiquette. ;)
