how to remove paste from cpu
fox-amd
and do i need to apply a thin coat of AS5 in a small area to the base of my new heatsink when reinstalling everything
The AS5 should go on the core of the processor, not the base of the heatsink.
I's probably a good idea to rub a small amount onto the heatsink to force it into the small voids and cracks.
Uh.. er.. yeah..
*flees*
What?
I should have noted that that is IN ADDITION to the paste you put on the core. You're right about putting it on the core, but some people also smear a bit on the heatsink then wipe it off, just to fill the tiny imperfections.
