waseem
- Oct 14, 2008
i have seagate 500gb and wd 640gb how can i me them raid0?
but can i do raid 0 in thos ? and why you saying its not good with seagate?
I thought so too. The only other thing raid 0 gives you is a larger single volume. And spanning is a much safer way to do that than raid 0.^^ Just to clarify, RAID0 IS mainly about performance.
I wouldn't be surprised if you had less performance doing raid 0 with that seagate, than just using the WD640.
Not entirely. In theory, RAID0 is all about performance. In actuality, you get a little speed boost in certain, particular uses. RAID0's never lived up the hype surrounding it.The person who said raid 0 does not give you increased performance is incorrect.
I understand this. Even in my situation where I benched my 2 WD640's in raid 0, I only gained about 50MB/s in a synthetic benchmark. Who knows what the real world performance was? Most likely much less, as to why I never noticed the difference and went back to 1 drive.Not entirely. In theory, RAID0 is all about performance. In actuality, you get a little speed boost in certain, particular uses. RAID0's never lived up the hype surrounding it.
That would be a good idea. Any applications that you need speed with, put on the 640. And things like Movies/mp3's/patches, store on the 500.As for the OP's system, I'd use the 640 GB as your primary system volume, and your 500 GB as the data storage drive.
