Hi Guys,
I have an asus m2n32 sli delux I have put together outside a case. I plan to be running it this way. Can I use a jumper as an on switch? What is a good option for a real switch?
I'll go check some of the local computer stores, any thoughts though what I should be looking for to fix this?
I could probably use a reset switch as well.
Everything else is hooked up and ready to go.
