D
Deleted member 79192
Guest
Well I took the plunge and tried out folding... I figured that since I leave my computer on pretty much 12/7 (only off at night) I might as well put those spare cycles to good use and for a dedicated cause. It turns out it works quite well! I imagined it bogging down my CPU power while I'm trying to do stuff but it doesn't. The program works quite well at only using spare CPU cycles and not interfering with other work.
Anyways I figured I'd join the [H]orde folding team since I've been a member of these forums for a long time and the community has helped me out a lot and stuff. So I went to the main site but it couldn't really answer my question. It didn't provide a solid guide on how to set myself up on your team... Is it really as simple as simply adding the # 33 to my team slot thing in the configuration section of the program?
