I need some help from some that have been around for a while
When I hooked up multiple hardrives, Sata had just come around, so never did the same with IDE. How do you do the same with IDE? Theres only 2 IDE slots on the ribbon cable. Do I need a special cable or a Controller card?
I have IDE and Sata connectors on the motherboard.
I have 2 IDE hardrives and 1 Sata, and a DVD Burner.
Thanks!
Thanks!
