- May 18, 1997
There has been a considerable amount of discussion since the launch of the AMD Radeon RX 580, that the RX 480 can be flashed with an RX 580 BIOS. Funky Kit has put together a step-by-step guide that outlines how to do this at home. Now why would you do this? Some users are reporting better overclocking rates, but this is going to differ card to card for sure, depending on the hardware used on your specific card. Worth keeping in mind is that this certainly comes with the risk of bricking your card, so tread lightly and weigh the rewards you might get.
"WARNING: Flashing your AMD Radeon RX 480 to RX 580 can be unstable and could even kill it! DO NOT ATTEMPT to flash your graphics card if you do not know what you are doing. Funky Kit and it’s staff or members can not be held responsible for any damages caused. You have been WARNED!"
