How to flash without floppy?
Hupo
Hi (pc specs in sig) i just downloaded the correct driver for my mobo. How do i install this onto my mobo? Its the rs480 ms 7093 mobo.... is there a way to put it on a cd and boot off it? ty
Doesn't MSI have a Bios update program for Windows? LiveUpdate3 or something like that? I've used it before. It worked fine for me.
nope, I formatted my hdd and restarted from scratch and all
u can run off boot cd
or run off USB drive if your mobo can support it
I(illa Bee said:
AMI Bios or Phonex? [/Spell check that]
Phoenix* :D. Close enough though. Anyway, there should be instructions install via floppy on the MSI web site right? If not, why won't he just take the 10-20 minutes reinstalling Windows for that Live Update software? :confused:
I'm sure if he has internet access, and a Windows CD installer, but he would have gotten the jobe done by now...
