How to disable memory tests etc on startup - help!!!
bigweed
Hi all
I have an MSI K8N NEO Plat mobo, and cant figure out how to disable the mobo from testing the memory, hard drives etc on startup. I recently reinstalled windows etc, and its all running smoothly, but I cant find the option in the bios to disable these tests. It never used to do these tests before reinstalling windows, so there must be a way of disabling them, so can anyone point me in the right direction? I have tried everything obvious in the bios, but nothing has worked yet!
Also, after reinstalling my Creative Audigy 2 soundcard, it brings up a Creative splash screen upon startup, as soon as the desktop shows after login. Does anyone know how I can stop this stoopid splash screen?? As it never used to pop up before either.
All help most appreciated
Thanks
Bigweed
What does it say when it's testing? The only bios option that I can think of is to enable fast boot or something like that. Sometimes your bios will hang a little bit on hard drive detection if you have a USB device plugged in.
its going to test your memory. but check out your bios "advanced bios options" page or something like that. might have a way for you to disable the other stuff.
click start
click run
type msconfig
under the startup tab, look for something that corresponds to the creative splash screen. then disable it.
Thanks for the msconfig tip, that worked a treat! Will check bios next time again - i have already done the enable fast boot option - not sure what else it could be
