GreatestOne
- May 15, 2005
For any given mobo/bios, how do you know the max voltages from the core voltage to the chipsets to the GTL etc without frying anything? The obvious is temperature, but what if the temp stays low? Somehow I dont think I'll still feel safe raising the core to 1.7V or something at 65C on load. There are 10-15+ different voltage settings, so is there some math you can do to figure out such things? Or is is simply experience and feel?
I dont like uGuru much but it seems it automatically resets voltages after restart. and not sure exactly sure what its doing, whether it is applying safety or if it is just matching the attempted new clock setting automatically... I dont feel like I can trust that anyways.
Additional Info: (I cant get above 3.66ghz it seems... here are my current stats)
